http://corporaterecords.biz/RecordWordPress/
Pete
now THAT'S awesome!!!!!Corporate Records wrote:Hi, glad you like it. I just posted a sound clip. You can check it out here: www.corporaterecords.biz/Copper.wav . It's guitar and drums. It was cut with a sapphire stylus. This is just a prototype. The finished version will have flash memory circuitry built into it so that you can plug a usb cable directly into the record and download the songs!
Cool. Its like a DIY Direct Metal Master. I wonder if you could 1 step it. hahaha. How cool would that be?Corporate Records wrote:Hi, glad you like it. I just posted a sound clip. You can check it out here: www.corporaterecords.biz/Copper.wav . It's guitar and drums. It was cut with a sapphire stylus. This is just a prototype. The finished version will have flash memory circuitry built into it so that you can plug a usb cable directly into the record and download the songs!
So short DMM runs (1-steps?) involve only mother cuts, but to make multiple sets of sons requires the clerk to cut a defacto grandmother disc which will be electroformed into a father...?Aussie0zborn wrote:Good point. But you are cutting the master first, which may or may not be used as a mother. For large runs, a nickel mother would be made as DMM parts stain easily. I would think that today the runs are small enough to make the required one or two sets of stampers.
Thanks chris.mossboss wrote:Copper preheated not relevant
Cutting angle zero or negative
Stylus heat not relevant
My advise instead of half speed cutting if you can do it at double speed
The best results are at around the 400 rpm but it is hard to control or do that in cutting audio so double up the speed if you can which I am sure you can
Sorry, I was exhausted posting that last nightpetermontg wrote:Thanks chris.mossboss wrote:Copper preheated not relevant
I would have no way of speeding up the TT. would i induce much problems at half speed. I wouldn't have anyway of cutting unless done at half speed.
This is what has my brain saying "don't bother", without the right setup the cost of stylus alone to cut a small run will offset any profit at all, if any, it would be marginal.mossboss wrote:P
Dont be surprised if you dont go through styli like there is no tommorow
You dont want to ruin £50 styli for a £5 piece of PCB
