Rekocut system.....
dietrich10
Rekocut system.....
Post: # 14246Unread post dietrich10
Fri Apr 15, 2011 5:07 pm
Ok added a Rekocut system....
TR43H turntable with M-12S cutter+ R8B amp and Audax head....
But already seems the lead screw is screwed...no idea how to get the head to engage.........
i'll post pics if i remember how to do it later
D
cutting lacquers-vms70 system
mratx
Post: # 14253Unread post mratx
Fri Apr 15, 2011 9:27 pm
The spring behind the half nut should keep the head engaged unless you squeeze the lever to release it, at least as long as the screw adjustment on the lever is set correctly. On mine if you have it adjusted incorrectly, you can't get it to disengage. Sounds like you may be missing a part.
Does your R8B have any impedance markings? I have one I'm fixing up, but I don't know what the impedance is for the output to the cutter head.
dietrich10
Post: # 14261Unread post dietrich10
Sat Apr 16, 2011 8:19 am
feel like something is missing. since first time with a rekokut not sure which piece.
malatesta
Rekokut amp.
Post: # 14285Unread post malatesta
Sat Apr 16, 2011 9:43 pm
dietrich10 wrote:feel like something is missing. since first time with a rekokut not sure which piece.
My amp. the R8B works with an Audax 8 Ohm, on the recording side, and I plugged an 8 Ohm speaker on the playback side, for the monitor I'm using a vintage headset. Till now everything is working, I have fix the amp. but I'm using it only as amp, bypassing the preamp section. I'm using a Marantz 1030 as preamp. I have recapped the R8B and changed the two 6973, with a pair NOS. and I check resistors, plus I replaced the bridge diode. It is a good amp, with plenty of power for wath you need by mono cutting. The voltage on the cutting head should not be over 2,5V when recording.
dietrich10
Post: # 14289Unread post dietrich10
Sun Apr 17, 2011 9:07 am
which replacement stylus on the audax?
malatesta
Post: # 14294Unread post malatesta
Sun Apr 17, 2011 3:40 pm
dietrich10 wrote:which replacement stylus on the audax?
The short ruby from Transco 362. The stylus has the coil around the ruby, so I made a box with a voltage regulator for 1.5v dc, and the temperature of the stylus is constant 40'C. I can cut the dub from Apollo very well, but the hot stylus dosen't work with old dub, for that you need a little bit of fortune and the old type of stylus ( vintage) from audiopoint.
dietrich10
Post: # 14296Unread post dietrich10
Sun Apr 17, 2011 4:24 pm
thanks malatesta
malatesta
Post: # 14304Unread post malatesta
Sun Apr 17, 2011 6:57 pm
dietrich10 wrote:thanks malatesta
Good luck to you, sometime can be tedious work on this old machine, but at the end the resoult will be fantastic.
dietrich10
Post: # 14350Unread post dietrich10
Tue Apr 19, 2011 1:04 pm
man forgot to bid on ebay! whoever won the m12s wnt to sell it to me?
JayDC
Post: # 14351Unread post JayDC
Tue Apr 19, 2011 2:05 pm
wy don't you use auction sniper, everyone else does..
dietrich10
Post: # 14356Unread post dietrich10
Tue Apr 19, 2011 2:58 pm
i need to set sniper back up
argh!
$62.50!
dietrich10
Post: # 14357Unread post dietrich10
Tue Apr 19, 2011 2:59 pm
argh!
$62.50!
d1rk
Post: # 14445Unread post d1rk
Thu Apr 21, 2011 10:44 am
DANG DIETRICH!!! THE ONLY REASON I DID NOT TOUCH THIS AUCTION WAS OUT OF RESPECT FOR YOU WINNING IT!!! DUDE!
Post: # 14468Unread post mossboss
Thu Apr 21, 2011 9:49 pm
May be we all bid for all and any cutting gear
When any one posts up an ebay item in the classifieds section here we can signal our interest to each other
Say two or three or five of us bid assuming its been won by any of us here we put it up here for the winning bid plus whatever cost's for any one that wants it needs it
We can than have a parallel market for cutting related gear instead of letting go into another basket case which may never see the light of day
Having said that I do not want any one bidding for the empty VMS cabinet for me Please!!!
"The Vinyl Truth"
Emilien03
Re: Rekokut amp.
Post: # 47799Unread post Emilien03
Mon Sep 11, 2017 10:45 am
@malatesta
Do you remember what capacitance values / voltage rating did you use to replace the "can style" capacitor with 4 sections?
thanks!
