List of confirmed cutting room wich are working from tape
Nickou
Post: # 15887Unread post Nickou
Wed Jul 13, 2011 6:55 am
Can we make a list of confirmed disc cutting studios wich are working 100 analog ?
If you cut masters for vinyl records from tape please list your details here.
If you cut also from digital source only, please also list your details in the topic titled "List of Confirmed confirmed disc cutting studios"
Nickou
Post: # 15888Unread post Nickou
Wed Jul 13, 2011 7:40 am
There is one in Barcelona , Spain
www.reverse-primecut.com
tape machines with preview deck are :
Telefunken M15 1/4 inch , 7,5/15 inc per sec
Studer A80 1/4 inch , 7,5/15 inc per sec
we will have soon a Studer A80 1/2 inch , 15 /30 ips
I usualy use SM911 tape , sometime SM900
the transfert desk is a Neve A5424
and the cutting machine is a Neumann AM32b with SX74, SAL 74 and Stuka / Vinylium Ultrapitch 98
Nickou
Post: # 15889Unread post Nickou
Wed Jul 13, 2011 7:41 am
gengy
Post: # 15906Unread post gengy
Thu Jul 14, 2011 12:10 pm
Hi All!
Here in Elettroformati we can cut lacquers from tapes.
we have:
STUDER A 812 1/4 inch
STUDER A 80 1/4 - 1/2 inch
MCI JH 110 1/2 inch
cheers
Alessandro Di Guglielmo
Mastering and Disk Cutting
gold
Post: # 15908Unread post gold
Thu Jul 14, 2011 4:18 pm
I have the only 1" 2 track preview deck in existence. Custom made by Dan Zellman and John French. I also have 1/4" and 1/2" A80 preview decks.
d1rk
Post: # 15918Unread post d1rk
Fri Jul 15, 2011 12:28 am
Hey Paul
You cut something for me whilst at DIGIROM? I think it was called, GOOD GUY you are...
Nickou
Post: # 15921Unread post Nickou
Fri Jul 15, 2011 7:13 am
gold wrote:I have the only 1" 2 track preview deck in existence. Custom made by Dan Zellman and John French. I also have 1/4" and 1/2" A80 preview decks.
Hey Paul,
That is fantastic !
how the records are sounding with this beauty ?
Do you have a ref of a record we can buy cutted from this machine ?
thanks
gold
Post: # 15923Unread post gold
Fri Jul 15, 2011 9:24 am
Hey Nickou,
The machine is only a few months old. I have only cut one record for production and it's not out yet. It's by Wheatus. I'm not sure when the release date is. I don't anticipate the machine getting much use. It's there if anyone needs it! I'm building a very elaborate A/B path console and this is a companion piece to it.
Yes, I was at DigiRom. That was a long time ago. At least eight years.
flozki
Post: # 15926Unread post flozki
Fri Jul 15, 2011 1:54 pm
to fill up the list
i do 100% analog cutting
either at the ex-vinylium cutting room:
Studer A80 1/4 inch, neumann SP79 console, Vinylium ultracut amps, vms70 with SP02 and vinylium pitch98, SX74
at my cutting room:
Studer C37 (no preview) or MCI with preview heads, vinylium level controller, UA100 tube equalizers, 1178, neumann vms82 converted to laquer, vinylium ultracut, sx74 or SC99
at the moment i do at least 1 full analog production each month. not very busy but way better than 5 years ago. then it was once a year to cut full analog
Post: # 15935Unread post mossboss
Fri Jul 15, 2011 4:22 pm
I am on Flozkis camp of about a year ago but I been there for years
Vms 70 SX 74 B rack, with an SX74, SX45 the only one still functioning, as well as a Westrex and a Haeco plus a Fairchild 914 Never used it Real weird set up, so plenty of choice in heads, including an Sp 72 console with a stack of extra Neumann modules all used constantly which is fine
In so far tape! Weeeeell
Ampex 1/4 Two track, another full 24 track as well about 3 or 4 Revoxes including a Studer 1/4" deck
Tape decks above are fitted with preview heads but there is also a variety of other tape decks
Otari's Frostexe's Akai's etc valve and solid state from various eras
Around about 6 or 8 may be more including a Rola locally made valve tape deck, thats Australian, all gathering dust
The next time I will buy a boat I will save some money by forgoing the anchor and use all of the above tape decks for an anchor
What a waste of hard earned money
The analogue chain/tape dream has just and only stayed with me
Arhgh well so much for artists with an analogue bent
"The Vinyl Truth"
concretecowboy71
Post: # 19717Unread post concretecowboy71
Thu May 17, 2012 3:10 pm
You can add Well Made Music to this list.
MCI JH110 preview 1/4" tape deck.
Cut my first lacquer from tape last week.
Well Made Music
Didier S
Post: # 20114Unread post Didier S
Sat Jun 16, 2012 5:02 pm
TIMMION CUTTING LABORATORY. Cutting straight analog signal from 1/4" tape with a studer A-80 specially modified for PRE/MOD ANALOG SIGNAL TO SP79, VMS70, SX 74, ORTOFON HIGHFREQ LIMITER, TIMMION PEQ, API2500, AM670, ... contact: didier at timmion.com
Lex
Cutting from 100% analog from tape
Post: # 20711Unread post Lex
Mon Aug 13, 2012 9:16 am
Hi, you can also add me also to the list.
I have here a Studer A80 preview machine which came from Townhouse.
It is the one designed for the VMS 80, which is also here of course and some 100% analog transfers took place already.
With kind regards,
Lex
www.thevinylroom.nl
bancho
Post: # 20719Unread post bancho
Mon Aug 13, 2012 2:14 pm
phewwww!!!! I saw the studio pictures... looks like a dream studio! :D
EvLoutonian
Re:
Post: # 56152Unread post EvLoutonian
Tue Jul 07, 2020 9:08 am
Lathe still in action (in Melb?), Chris?
Cheers,
Ev
