who cuts masters here?
humongous
Post: # 13458Unread post humongous
Thu Mar 17, 2011 9:10 pm
I cut the twilite singers "dynamite steps" record.
Jeff Powell
drybonz at aol dot com
piaptk
Post: # 14628Unread post piaptk
Wed Apr 27, 2011 3:57 pm
I'm going to cut my first lacquer for mass production tonight. So, I have a couple questions.
If I'm mastering an LP on a 14", can I use the otuside .5" to test to make sure I've got the groove depth and other settings correct? Everything outside that will be lost in the plating process, right?
If not, can I use the back of a lacquer that has been cut? I.e. if I start cutting on one side of the lacquer, and the suction loses the swarf, etc, I can flip it over, right?
You can tell the "good" side of an apollo lacquer because it has the stamp in it, correct?
dietrich10
Post: # 14630Unread post dietrich10
Wed Apr 27, 2011 4:09 pm
yes
watch for scuffing
You can tell the "good" side of an apollo lacquer because it has the stamp in it, correct?[/quote]
the side without the # stamp is the good side
cutting lacquers-vms70 system
piaptk
Post: # 14633Unread post piaptk
Wed Apr 27, 2011 6:21 pm
Great! Thanks!
philbrown
Post: # 15729Unread post philbrown
Mon Jul 04, 2011 4:49 pm
cymbalism wrote:
With the Costello records, I own the original US presses and the original UK presses so I did compare those which as always it seems the UK versions blew them out of the water. I own the Bungle cd as it never had a vinyl issue until late last year and the record was over a decade old. The MCR I bought on cd when it came out and the vinyl when it also came out which was like 4 months apart.
The US releases were cut from copies, not the original masters.
Phil Brown
philbrown
Post: # 16311Unread post philbrown
Mon Sep 05, 2011 5:14 pm
dietrich10 wrote:If I'm mastering an LP on a 14", can I use the otuside .5" to test to make sure I've got the groove depth and other settings correct? Everything outside that will be lost in the plating process, right?
yes
watch for scuffing
the side without the # stamp is the good side[/quote]
Typically the good side is easy to spot.
Phil Brown
Post: # 16317Unread post opcode66
Mon Sep 05, 2011 7:22 pm
The side with the stamped numbers is the Non-Prefered side. I.E. the side you should not cut....
The side with nothing on it is the side you should cut on a master lacquer. I can dig up and scan some documentation from Transco (I think) that specifies this.
Post: # 16322Unread post mossboss
Tue Sep 06, 2011 6:18 am
piaptk wrote:I'm going to cut my first lacquer for mass production tonight. So, I have a couple questions.
Great another one on line
piaptk wrote:If I'm mastering an LP on a 14", can I use the otuside .5" to test to make sure I've got the groove depth and other settings correct? Everything outside that will be lost in the plating process, right?
Fine make sure you don't run the had across to the start of the track as you will introduce weakness on the stampers
Lift the head move it to the start
piaptk wrote:If not, can I use the back of a lacquer that has been cut? I.e. if I start cutting on one side of the lacquer, and the suction loses the swarf, etc, I can flip it over, right?
If you set your cutting depth on one side during test you will loose some of it it if you flip it over Not a good idea The answes above should deal with that any way
piaptk wrote:You can tell the "good" side of an apollo lacquer because it has the stamp in it, correct?
answered
Best of luck with it all keep at it
Cneers
"The Vinyl Truth"
