Technics MN6042 Pitch IC
JPJones
Post: # 40650Unread post JPJones
Sun Feb 14, 2016 7:49 pm
As most folks familiar with the Technics 'tables with digital pitch control know, the pitch synthesizer chip, MN6042, is very static sensitive and prone to failure. What seems to have escaped everyone's attention is that most working chips aren't working right. I've measured several samples, and they all essentially exhibited 8Hz frequency drift. This chip generates the quartz reference for the motor, so any drift at all isn't good.
Being an SP-10 MK3 owner and wanting the best possible performance from my 'table, I decided to design a modern replacement for the MN6042 chip. You can read about it here: http://fidelisanalog.com/product/mn6042/. It's designed to be a direct drop-in replacement, with far better performance and reliability than the original. I had a batch of boards made so I'm making some completed units available to help others out and hopefully recoup some of my sunk costs.
As these utilize a micro controller I was able to make a version with expanded pitch resolution. This version allows 0.01% adjustment - after setting the normal +/- 9.9% adjustment, you hold the reset button down for two seconds to enter hundredths mode, which allows +/- 0.09% adjustment.
If you purchase one please make a comment in the order notes that you heard about it here so I can contribute a portion of the sale back to the forum.
Sillitoe
Re: Technics MN6042 Pitch IC
Post: # 40656Unread post Sillitoe
Sun Feb 14, 2016 10:39 pm
Great work JPJones!!!
I need to get a MK3 to put one of these in :D
JPJones
Post: # 40657Unread post JPJones
Sun Feb 14, 2016 11:21 pm
Or an SP-15, or even an SP-02 but I can't be 100% sure on the latter as I've never seen a schematic for it.
sakuszi
Post: # 40658Unread post sakuszi
Mon Feb 15, 2016 12:25 am
JP Jones , is very interesting for the engine Technics MK3, please show me 10 msec on the oscilloscope, please enable probe in point 1, IC204, FG, MK3, oscilloscope set at point 1 m sec / cm and lightly with your finger to slight brace plate turntable, please make a short video on you tube.
JPJones
Post: # 40661Unread post JPJones
Mon Feb 15, 2016 2:03 am
If I remember the next time I have my controller open. There'd have to be a far wider frequency drift than my board has to manifest as an issue visible with that test though.
Bonati
Post: # 40837Unread post Bonati
Mon Feb 22, 2016 7:03 pm
I didn't see them on the compatibility list but I have to ask anyway - is this compatible with the lower SP-10s? I own a MK2.
Always looking for a SP-02 but not holding my breath.
JPJones
Post: # 40844Unread post JPJones
Tue Feb 23, 2016 5:05 am
The only SP-10 that uses the MN6042 IC is the MK3 - it's only used in the 'tables that have digital variable pitch.
Bonati
Post: # 48844Unread post Bonati
Wed Jan 03, 2018 11:21 pm
I noticed these are now out of stock on your site - any chance you'll be re-stocking them? I'm now in the market for 2 if you've got them.
Nascimento
Post: # 50659Unread post Nascimento
Fri Jun 22, 2018 1:53 pm
Hi Mr. Jones
I'm Carlos, I need your help!
I have a SP10Mk3 that has stayed the last 28 years, stored on a shelf, is very well maintained, but needs a JP6042.
Please, can you sell me one or two units and send me in August?
greetings
Carlos
aviasom@gmail.com
