scraping noise
fredbissnette
scraping noise
Post: # 47080Post fredbissnette
Fri Jun 09, 2017 2:11 pm
im gettig a scraping noise on my cuts now im sure it has to do with angle/weight
its a high pitched whine and not loud but i dont want it on my cuts
any ideas?
im using tungsten
Jccc
Re: scraping noise
Post: # 47083Post Jccc
Fri Jun 09, 2017 4:36 pm
It might be that the cutting needle could be getting dull?
Have you tried exchanging needles for a fresh one?
fredbissnette
Re: scraping noise
Post: # 47084Post fredbissnette
Fri Jun 09, 2017 5:14 pm
just did that
heres what it sounds like
https://vid.me/vp1l
Jccc
Re: scraping noise
Post: # 47085Post Jccc
Fri Jun 09, 2017 5:48 pm
It kinda sounds like its picking up the vibration from the rubber puck runnin the platter?
fredbissnette
Re: scraping noise
Post: # 47086Post fredbissnette
Fri Jun 09, 2017 6:08 pm
could be
but its a brand new wheel and its lubed well on the bearing
fredbissnette
Re: scraping noise
Post: # 47087Post fredbissnette
Sat Jun 10, 2017 1:15 am
im chalking it up to weight i switched drivers in my head and these ones i have now are slightly heavier and required a different mounting system
im going to make a counter weight
fredbissnette
Re: scraping noise
Post: # 47092Post fredbissnette
Sat Jun 10, 2017 1:37 pm
the counter weight did not help
im stumped ive been cutting steady for nine months and then this
weird
help!!!!
fredbissnette
Re: scraping noise
Post: # 47093Post fredbissnette
Sat Jun 10, 2017 9:26 pm
got it sorted!
weight and rake was the problem
cheers
fred
@madstyluspressure on insta!!!
heres a vid of the problem
https://vid.me/5xp8
fredbissnette
Re: scraping noise
Post: # 47094Post fredbissnette
Sat Jun 10, 2017 9:31 pm
10-15kg of torque i meant!!!!!
fredbissnette
Re: scraping noise
Post: # 47095Post fredbissnette
Sun Jun 11, 2017 10:43 pm
im still getting a noise after rebuilding my head and slacking the angle as much as possible
if i cant get this sorted im probably going to sell my rig
Gridlock
Re: scraping noise
Post: # 47096Post Gridlock
Mon Jun 12, 2017 12:18 am
Oh dude you know it's something easy don't give up!
fredbissnette
Re: scraping noise
Post: # 47097Post fredbissnette
Mon Jun 12, 2017 12:30 am
i took the entire rig apart and im going to take my time and source this out
im too invested in time
cheers
fredbissnette
Re: scraping noise
Post: # 47102Post fredbissnette
Mon Jun 12, 2017 4:33 pm
fredbissnette
Re: scraping noise
Post: # 47104Post fredbissnette
Mon Jun 12, 2017 8:58 pm
https://www.instagram.com/p/BVQnd8VDMaH/?taken-by=madstyluspressure&hl=en
https://www.instagram.com/p/BVQoHtwDKDf/?taken-by=madstyluspressure&hl=en
im cutting slightly wet as well leaving a slight film of wax on the disc
music sounds good and the grooves track well
fredbissnette
Re: scraping noise
Post: # 47119Post fredbissnette
Wed Jun 14, 2017 9:24 pm
i got it sorted
https://vid.me/wU93
