my carbide stylus
juba bc
my carbide stylus
Post: # 49460Unread post juba bc
Mon Feb 26, 2018 4:33 pm
Hi, I am trying to make my own carbide stylus, I have managed to make the surfaces mirrored, but I still have a white noise ... suggestions on how to improve will be very welcome
jjgolden
Re: my carbide stylus
Post: # 49464Unread post jjgolden
Mon Feb 26, 2018 5:46 pm
very cool!
Are you using Heat?
Are you cutting in Lacquer or plastic?
juba bc
Post: # 49465Unread post juba bc
Mon Feb 26, 2018 6:21 pm
hi,I used a heater but I did not notice improvement, I'm cutting plastic
Post: # 49476Unread post markrob
Tue Feb 27, 2018 9:36 am
Wow, that looks really nice! Can you provide any info on the methods you used to form the facets? My understanding is that carbide, while very hard does not take as sharp an edge as high speed steel. Have you tried cutting a lacquer blank? That would go a long way to validating the sharpness of your edges. Have you tried HSS? Plastic is pretty tough to cut.
juba bc
Post: # 49477Unread post juba bc
Tue Feb 27, 2018 10:08 am
Hi Mark, I use a copper disk made of printed circuit board, and diamond paste to make faces and polish
I tried on steel with bad results ... I believe the diamond paste is not so good for polishing steel
I only have plastic to test, sometimes I get a quieter cut with carbide, but not always
juba bc
Post: # 49478Unread post juba bc
Tue Feb 27, 2018 10:34 am
Post: # 49486Unread post markrob
Tue Feb 27, 2018 3:29 pm
Great job on the template style faceter. Lover your DIY approach to a lap. I'll have to give that a try next time I have a go at this.
Fatrecco
Post: # 49488Unread post Fatrecco
Tue Feb 27, 2018 6:20 pm
Hey, I tested carbide too. There exists many kinds of it. The Problem is the dimensions of the powder/corn from which is this material is made of. I taked very fine one and tried to polish or lap it. Under the microscope I see the surface roughness. But with HSS you can get very sharp edges and a mirror surface under microscope. But in plastic the stylus tip was always scheisse(shit). So you get a surface noise in PC and PET. You have to messure the stylus tip radius and check out how sharp the edges are. Maybe when you use not fixed grind powder/corn there will sometimes apear some kind of hill sourround the workpiece(stylus). This will distroy the sharpness of the edges while the surface is fine.
I started my stylus grind Project again and build a little grinding/polishing machine too. But still find no material to cut in without noise. :(
Sorry for my bad english, I hope you understand what I mean. :oops:
juba bc
Post: # 49489Unread post juba bc
Tue Feb 27, 2018 7:58 pm
Hi Fatrecco, thanks for the information, I'll try other abrasives to try on HSS
the carbide I'm using and the one of plotter blades
sameal
Post: # 49905Unread post sameal
Tue Mar 27, 2018 7:38 pm
Wow!
That is pretty impressive!
juba bc
Post: # 49906Unread post juba bc
Wed Mar 28, 2018 7:30 am
when I cut plastic with this stylus, I have an incredible sound, very sharp and with excellent treble ... but I have background noise
The Shank
Post: # 49913Unread post The Shank
Wed Mar 28, 2018 12:36 pm
juba bc wrote:when I cut plastic with this stylus, I have an incredible sound, very sharp and with excellent treble ... but I have background noise
Same moh scale’s hardness than rubin or Sapphire. It won’t work on plastic.
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Cutterheads - HeLiX23
Post: # 49918Unread post tragwag
Wed Mar 28, 2018 4:32 pm
are you able to try embossing?
juba bc
Post: # 49922Unread post juba bc
Wed Mar 28, 2018 7:22 pm
this stylus is short, I think I would have to do a longer to press
grooveguy
Post: # 49968Unread post grooveguy
Wed Apr 04, 2018 10:53 pm
Congratulations, Juba bc,
You are doing important work here. There are limited sources of cutting sytli, and the more experimentation in this area, the better. Please continue your work and keep us informed.
With respect to your stylus, do you include "burnishing facets" in the geometry of your stylus point shape? These are important, as these burnishing facets polish the groove wall on a 'dynamic' basis; that is, as the groove is being modulated and as the groove exits the active recording area. This is a concept that is ignored by many who attempt to make their own recording styli, and a concept that is jealously guarded by those who make and sell styli on a commercial and professional level. There are AES papers on the subject, most penned by Frank Capps, who made styli for Edison, and by his daughter, Isabel, who worked with Peter Goldmark and others in developing styli for microgroove recording.
Keep up the good work!
juba bc
Post: # 49972Unread post juba bc
Wed Apr 04, 2018 11:23 pm
thank you very much for the comment here ... this is my great doubt, if these facets exist only for lacquer cutting or for cutting plastic too ... my focus here is only to cut plastics, and I have better results without the facets in that case
ilium
Post: # 49974Unread post ilium
Thu Apr 05, 2018 12:58 pm
juba bc wrote:thank you very much for the comment here ... this is my great doubt, if these facets exist only for lacquer cutting or for cutting plastic too ... my focus here is only to cut plastics, and I have better results without the facets in that case
I'd really love to hear what something cut or embossed with this sounds like... any chance of hearing a wav or mp3 of an example cut?
juba bc
Post: # 49975Unread post juba bc
Thu Apr 05, 2018 3:25 pm
ilium
Post: # 49976Unread post ilium
Thu Apr 05, 2018 5:52 pm
Sounds pretty decent!
