K8 Motor Tension Spring Hook
- soeffingodly
Hey Fellow Trolls,
So I was getting cute while being pretty unfamiliar with my K8's guts and accidently loosened the motor tension spring screw which in turn ended up unhooking from wherever it latches to on the other end. (I lost a screw inside the case which necessitated this endeavor) I've scoured the boards and went over the manual and motor, etc and can't seem to find where to reattach the hook to. I thought it was on the motor but I'm not seeing anything jump out at me. And I don't want to attach it incorrectly and cause more issues.
Thank you in advance!
Re: K8 Motor Tension Spring Hook
The sprint hooks on to the motor to make it "spring" away from resting against the turntable belt during the off position of the switch.
Alan Graves
Alan Graves
Oops! My bad. I previously told you the opposite. My memory took brain gap. The Spring hooks on to the bottom of the motor in a funny way through one of the air gaps in the housing to keep the motor tight against the rubber tire when running - and a protrusion on the motor switch pushes the motor shaft away from the tire when in the off position.
It's been awhile since I had a K8 - so maybe another troll can help you further.
Alan
Alan
- soeffingodly
Thank you Alan! I thought it went on the bottom as well but was moving the hook in different ways to see if it looked proper and it didn't but I can take another look tonight.Prestofan wrote:Oops! My bad. I previously told you the opposite. My memory took brain gap. The Spring hooks on to the bottom of the motor in a funny way through one of the air gaps in the housing to keep the motor tight against the rubber tire when running - and a protrusion on the motor switch pushes the motor shaft away from the tire when in the off position.
Alan
Hoping another troll better versed with the K-8's guts can assist with a bit more detail!
- soeffingodly
Found the little hole in the bottom of the motor. Got the tension spring hook attached. I think it is on correctly. Still fighting the dam platter hum in the grooves. Ugh.
- soeffingodly
PS I am an idiot. I should have taken a shot of how I attached the hook/spring. I might do it anyway. =)
- soeffingodly
Hey Gang,
So I noticed that my tension spring was on correctly but not attached to the correct place on the top so I had to tweak it last night. Here is a picture of how it goes on weirdly. There is a small hole the end sneaks in to. There is also a groove on the bottom of the motor for the actual metal to sit in.
STILL getting a hum from the K8 but I believe I have isolated it to the motor. I found grommets that fit pretty much perfectly like the originals. Didn't replace the bottom rubber cylinders though. (yet) Any trolls have any tips on getting the motor mounted quietly as opposed to giving me so much dam hum? I'll be making a single K8 post from all my research, parts, successes and failures. (many) I think I found a replacement for the rubber tire for the platter too. The rubber cylinders under the cover need to be hand made. Could not find anything suitable that fit out of box.
- buddybolden
I dont have too much time to sit here, so my post may be a bit "late" by now,
here in Europe all the 60hz AC lathe motors hum even more loaded with 50Hz mains. (not to say about the platter speed issue on 50hz, a different story).
What I've found and turn into practise design and use, on K-family prestos a good easy way to solve the hum is to replace the motor with an suspended axle, placed in place of the motor, where top of the axle serves as a capstan, and it's bootom is geared with a pulley. The motor is placed on a side of it (bad thing: original motor is going to be too big, u need a smaller replacement to house it inside a Presto cabinet) working as a belt transmission feeder (with i'ts own pulley) for the "capstan axle".
This way you reduce 2 issues:
1: Belt transmission doesn't transmit mechanical 60hz motor vibrations to the platter
2: properly tooled axle (a modern, ordinary $10 table fan rotor works fine) will give less flutter than original capstan.
Same as here:
https://www.youtube.com/watch?v=1RKpulkqJck
I hope I've expressed myself reasonably well
sorry for my english,
Jed
Same as here:
Jed
- soeffingodly
Thanks for the feedback! I've actually upgraded to a 6N and moved my K8 to another gent who wanted to get into record cutting. I appreciate the posting though!buddybolden wrote:Hi,
Same as here:
I hope I've expressed myself reasonably wellsorry for my english,
Jed
-S
