Hara 180 type recorder help
flashbk13
Post: # 54428Post flashbk13
Mon Oct 28, 2019 6:45 am
hi,
I have the hara m180 version disc recorder. On mine, the cutter head when lifted up to go to the platter/ record is not high enough to clear the edge of the record/ platter. If I remove the stylus (what type cutting stylus, long or short, mine is long) and rubber mat, it just clears. My manual is in Japanese (is there an English version somewhere?); Is there a height adjustment for the head or arm?. I looked around and couldn't find one. I thought I had maybe bent the arm as I had the mechanism out of the cabinet upside down on a thick blanket to work on loose items inside. That arm mech. is very sturdy, and looks straight. Now, when it was shipped (not from you) from Japan, I noticed the cutter head was jammed in the down position and I had to free it, so that may have done it (that middle spring metal was on the wrong side of the plunger that raises the head up and down, Any help would be great (all other functions seem to work properly). Thank you, Rick
EposLab
Re: Hara 180 type recorder help
Post: # 54455Post EposLab
Mon Nov 04, 2019 4:45 am
flashbk13 wrote: My manual is in Japanese (is there an English version somewhere?);
You can scan and have a translation using google translator,
if you have a android phone you can download the translator app and have a real time translation.
http:\\www.eposlab.gr
info@eposlab.gr
flashbk13
Post: # 54459Post flashbk13
Mon Nov 04, 2019 3:50 pm
Thank you EposLab for the reply, i'll try that. Rick
mysticfarm
Post: # 58229Post mysticfarm
Mon Apr 05, 2021 10:22 pm
Hey there! Did you ever end up scanning this manual? Would love to see it in any language available
Spiderxdeath
Post: # 58542Post Spiderxdeath
Sun May 09, 2021 5:10 am
I have a translation of the manual send me an email if you need it
Spiderxdeath
Post: # 58548Post Spiderxdeath
Sun May 09, 2021 5:51 pm
I’ve been using this machine for years and have had some great results after a bit of trial and error... has anyone successfully upgraded the cutterhead or made any other mods ?
Spiderxdeath
Post: # 58549Post Spiderxdeath
Sun May 09, 2021 6:14 pm
Actually I’m talk about the Hara VA 12” model
