Looking for center spindle clamp
- cheapthrills
Looking to clamp down blanks using hex screw. Does anyone have a link or info? Currently using parts from my local hardware store. I've seen a better clamp in your photos. Thanks!
Re: Looking for center spindle clamp
Hi There,
Something like this???
https://www.hifix.co.uk/michell-turntable-clamp?gclid=EAIaIQobChMIl_b3uYDn6wIVAs53Ch0ERwPBEAQYBCABEgKbL_D_BwE
Regards Soulbear
Regards Soulbear
- cheapthrills
Like this with a set screw.
Agnew Analog makes them here:
https://agnewanalog.com/low-profile-record-clamps.html
- cheapthrills
Agnew Analog product looks great, but there is no price and no link to buy on the website.
Why not send an email?
- cheapthrills
Well yes I sent email when I visited the website. My other option would be to tap the center spindle or have it modified (replaced) with a threaded part. Anyone doing this? Its for a sp10.
- cheapthrills
I like SoulBears recommendation, I ordered the Michell clamp but my spindle on the SP10 is too short and the Michell clamp does not grab.
MMmmm now I'm Curious?????? Soulbear was advised by no less than 3 other Bears who ran some Tests and found the Michell Clamp and SP10 Combination to Work Fine!!!cheapthrills wrote: ↑Mon Sep 14, 2020 1:53 amI like SoulBears recommendation, I ordered the Michell clamp but my spindle on the SP10 is too short and the Michell clamp does not grab.
If what you say is true, I must go and have words with these Naughty Bears!!!
Regards Soulbear
I took a metal 45 adapter, tapped it with a set screw. Works great!
- cheapthrills
Hi Soulbear, if my SP10 was in original condition the Michell Clamp would work great. But as you can see the spindle is cut short.
I'm not sure if you have enough spindle to use the Kab Super Record Grip but I have had good success with it.
https://www.kabusa.com/usagrip.htm
- cheapthrills
Thank you kcdonahue
the michell clamp is much better than the standard VR clamp, but I can't use it for cutting, it's too tall!
I took two pics of the KAB record clamp and posted them on imgur for clarity. It's clamping mechanism is quite different than the others and it is very light weight. I'm not sure how tall the Mitchel clamp is, but this on is approximately 1 inch tall.
https://imgur.com/gallery/TB38MGP
KC
KC
