- record cutter 76
Search for a feedscrew and turntable bearings for old neuman
My latest find is a Neumann record cutter from the 30's. It will need a new feedscrew and new turntable bearings. Where can i buy that ? I while need a motor for the turntable, too. Please help me. Thanks in advance.
- record cutter 76
Re: serch for a fedscruw and a turntable berings to a neuman
- record cutter 76
- record cutter 76
It is a ortophon cutting head on the lahte to day i sholud see if the head coils are ok
Try and contact Florian Kauffman ( https://www.flokason.ch/) , or Jesusfwrl ( https://agnewanalog.com/about-us.html) and they may be able to steer you in the right direction, by the way what a great find!!! Congratulations Best Regards Soulbearrecord cutter 76 wrote: ↑Sat Mar 20, 2021 4:34 ammy latest find is a neumann record cutter froam the 30 s it whill nedd a new feedskruwe and a new turntable berings wher can i buy that ? I while need a motor to the turntable to pleas help me
- record cutter 76
thank you soulbear i hope that i can save this grate maschineSoulbear wrote: ↑Sat Mar 20, 2021 4:57 amTry and contact Florian Kaufman ( https://www.flokason.ch/) , or Jesusfwrl ( https://agnewanbealog.com/about-us.html) and they may be able to steer you in the right direction, by the way what a great find!!! Congratulations Best Regards Soulbearrecord cutter 76 wrote: ↑Sat Mar 20, 2021 4:34 ammy latest find is a neumann record cutter froam the 30 s it whill nedd a new feedskruwe and a new turntable berings wher can i buy that ? I while need a motor to the turntable to pleas help me![]()
Wow! Great find!
- record cutter 76
- record cutter 76
Nice...thats gonna need a TON of work. Good luck!
- record cutter 76
Yes i understand that but it is a numann that is pretty cool
- dubcutter89
Hi!
Great find!
That is the very early version - interesting is the turntable with dots instead of line stroboscope, I've seen a similair one on another machine in sweden but couldn't find it on my computer now...
Normally the bearings and feedscrew are very good and don't have to be replaced unless they have been destroyed by wrong operation or if the machine was droped downstairs.
If the shaft is bent you have a problem.
The bearings are standard parts and if you disassemble the machine you can read the numbers and order new ones (if needed)
The feedscrew is a bit special, and probably your machine still has a metal halfnut instead of the later plastic ones and therefore the screw shape has to be very accurate.
I would start with a good clean and oiling and see if you really need replacement parts!
BTW, on your picture is no Ortofon head, but something that looks like a Lyrec head. Simple moving iron design that does not need fancy electronics, probably a HiFi amp is good enough to test it.
Lukas
Great find!
Lukas
- record cutter 76
thaank you for yore tip on how to do it is a lyrec head yes but lyrec dident make ther heads that was ortophon and thats wy im wright ortophon best regards lucas by the way are you from sweden lucas ?
- dubcutter89
Hi!
No, not from Sweden. A snowy country more in the south...
How do you think Ortofon made heads for Lyrec?
A couple hours browsing my computer I found that other pic again hehe
Guess it is from a museum in Sweden, same custom dial-knob on the right hand side of the machine (pitch adjustement?).
This one has a Ortofon Mono head and an intersting long suspension spring.
Is that a 16 inch platter? No vacuum?
- record cutter 76
Sorry now i know the cutterhead is made by lyrec but the stereoheds that lyrec useed was made by ortophon
No vacuum. The knurled knob on the spindle screws down to hold the lacquer If I remember correctly, this has a left hand bread.
- record cutter 76
Yes it is missing some parts but it is no big problems
- record cutter 76
Re: Search for a feedscrew and turntable bearings for old neuman
Dubcutter89 yes My neumann has a 16 inch turntable sorry for the late awnser
