A Very Basic Record Lathe
ilovedrums247
Post: # 58182Unread post ilovedrums247
Wed Mar 31, 2021 9:46 am
Hello, I have been working on this lathe for about a year. Starting with a drawing and eventually onto cutting metal and soldering cables.
This week it all came together and i've just started cutting/embossing.
I've got the counter weight set to about ~80g-100g and have been toying with different springs for the cutter depth.
The needle is from Wilson Logan and set to about 7 degrees. I also experimented w a 15 degree rake but it made no difference.
I've got a heat lamp warming up the blank to about 30 degrees.
The 10" blank is from myshank and it does have a slight wobble but it's being held very securely to the platter.
The problem i'm having is that the cuts seems to be too deep, but when i adjust the depth spring i'm unable to find a spot where it'll cut a nice looking groove but also doesn't skip at some point in the rotation. The picture above is from the last cut i made magnified x150
As it stands, everything that's been cut sounds terrible.
Any ideas/solutions from fellow trolls would be greatly appreciated.
ilovedrums247
Re: A Very Basic Record Lathe
Post: # 58183Unread post ilovedrums247
Wed Mar 31, 2021 10:27 am
Also using myshanks antistatic wax
Crismgc
Post: # 59003Unread post Crismgc
Fri Jul 23, 2021 10:01 pm
Do you have an audio sample? Maybe is something about the speaker’s cones, some piece not attached well. With an audio sample maybe I can notice what it should be.
Crismgc
Post: # 59004Unread post Crismgc
Fri Jul 23, 2021 10:03 pm
The weight of the turntable needle is a factor too
boogievan
Post: # 59005Unread post boogievan
Sat Jul 24, 2021 3:52 am
Awesome build, ...247.
How wide is the groove, across the top, when it looks 'too deep'? (Does it look much wider than most groove-turns on known-playable 'embossed' cuts when viewed on your platter when using the same mic / objective?)
Is there any swarf-suction nozzle? (swarf strings visible on workpiece...)
The counter spring looks kinda 'sprung' and is attached at an angle. Normally, this is vertical. It can be behind or in front of the cutting head.
Is there a silicone fluid-filled dash-pot in that lift-drop box to dampen the oscillations of the counter-sprung pivot? If so, what's the viscocity? ...like, how many CentiStokes is its 'weight''?
- Tim E.
chris-zwarg
Post: # 59109Unread post chris-zwarg
Tue Aug 10, 2021 1:07 am
The grooves in the microscopic picture look terrible. Not sure whether you are trying to emboss or actually cut, but what is happening is that you are just scratching the surface. Unmodulated grooves must look mirror-like and smooth, without any of the small "fuzzy" structures seen in the image. Look at an unworn factory-pressed disc (preferably some classical music that tends to have extended passages at low volume, or use the silent grooves between tracks) to get an idea how it should look like. When the cutter touches the surface there must be no audible mechanical noise at all. If you hear any hissing, squealing, or screeching while cutting silent grooves, something is VERY wrong. Maybe the stylus tip is rough/broken, the angle is very wrong (it can e.g. happen when trying emboss at a "raking" rather than "trailing" angle, with the tip going against the movement of the disc), the weight is much too high, or the material unsuitable for embossing (Polystyrene or PVC rather than polycarbonate). To get a smooth groove without any of this scratching and screeching is maybe the most delicate and complicated aspect of constructing a lathe. Great precision is needed, as a stylus being off the sweet spot in terms of angle, but also position on the disc surface (in front of or behind, rather than bang-on the tangential line from the center spindle outwards), by a very small amount can already ruin the cut, especially on hard materials like Polycarbonate or PVC. Lacquers and wax are much more forgiving, which is probably one reason they were always the preferred materials for pro-grade cuts.
ilovedrums247
Post: # 59277Unread post ilovedrums247
Sat Aug 28, 2021 5:15 am
- Tim E.
Hi Tim,
Thank you.
The lathe has come along a little further since the first post, although the last couple months i've been lacking the time and energy to experiment (see: 9 m/o & 2 y/o).
The grooves have now gotten much closer to a 'normal' width, but in order for that to happen tho i needed to do two things.
-back off the cutterhead weight (now ~20-30g)
-build a lapidary to make needles
The picture from the first post was taken at an incorrect angle and also the grooves were WAY to deep (goodbye playback needle).
I haven't been able to cut swarf yet, so it's only embossing with metal needles. I also ordered some [0.6 x 0.6 x 3mm] CVD diamonds and have been slowly polishing them but need more diamond coated discs to do so. Hopefully they'll last longer/stay sharper then the steel ones. I've built a swarf catcher but don't have a side blower yet...That's all for "Phase 2" 8)
One big problem i'm having is cutting music loud enough, with grooves deep enough, that doesn't skip on playback. It has seriously made me consider also building a mono head and simplify it all a little more.
The counter spring has been totally changed and now hangs ~75º.
The dash pot is filled with "Team Corally differentieel olie 60ml - 5000CPS", but have considered going thicker and experimenting with different size cans. I've found some small aluminum 'pill/ear plug' containers that are very inexpensive and have rubber seals.
I'll upload pictures soon.
ilovedrums247
Post: # 59278Unread post ilovedrums247
Sat Aug 28, 2021 5:17 am
Not yet, but when i get something i'm happy with i will upload it with some pictures and more info.
ilovedrums247
Post: # 59280Unread post ilovedrums247
Sat Aug 28, 2021 5:26 am
Hi Chris,
Yes, they did not sound good either, but thankfully much has improved. It's currently cutting silent unmodulated grooves. I'll upload pix soon.
ilovedrums247
Post: # 66746Unread post ilovedrums247
Wed Jan 29, 2025 5:45 am
It’s been a while but I’ve been slowly tinkering on the lathe.
Today I adjusted the suspension height with the, soon to be installed Caruso head. Then it needs a chip pickup tube, and a few other tweaks until it can get the upgrade.
Thanks to Dubcutter89 for building the preamp.
Thelatheofus
Post: # 66757Unread post Thelatheofus
Thu Jan 30, 2025 7:25 am
That looks amazing ! Are you using a servo motor to move the carriage ?
zdenek
Post: # 66787Unread post zdenek
Sun Feb 02, 2025 1:04 pm
Your machine looks good!
I'm not sure if your turntable is attached to the base or is on rubber shock absorbers, because if so, that may be a problem. The force acting on the knife while cutting the record is quite large and is almost as much as the pressure of the knife on the record, which causes instability between your machine and the instability of the turntable, i.e. opposing vibrations and mechanical resonance of the structure of both drive units. If you can stiffen the turntable, try it. I have no experience with these Chinese diamond knives, but they are very cheap on Aliexpress, I see them ranging from $25-$100 per piece, perhaps they are not sharp enough and this may also cause problems.
A nice Swiss head. I have never heard its sound. If you could demonstrate the operation of the head itself, I would be happy to listen to it. Maybe I will decide to buy it in the future if my experiments fail me, as long as the price is affordable for me... :)
ilovedrums247
Post: # 69005Unread post ilovedrums247
Mon Feb 02, 2026 9:00 am
A quick update…
the Caruso is installed and cutting. It sounds incredible.
There is a slight drop around 7k, but I hope with more calibration and tinkering that can be improved.
New turntable and tonearm
Amplifier is now PAS Audio 2002, with raw aluminium faceplate.
Vacuum added, recently changed to latex tube from silicone and there’s less chip build up inside tube
The pitch motor is a stepper, I tried a brushless dc with reduction but that caused way more vibration. I’ve also reversed the belt so it runs on the smooth side.
The technics is secure on the ‘desk’ which is mdf+aluminum profile filled with sand/concrete.
In the pipeline is a microscope upgrade.
One thing I’d like to add is a “speaker/magnet-coil” in the suspension, very much like a Neumann SA-74, But I can’t understand how that functions with the slight circular motion as the cutterhead lowers/rises.
I’ve also been looking at Wayne Kirkwoods Elliptical equalizer so I can be less reliant on working “in the box”. Maybe some else is already using it?
zdenek
Post: # 69011Unread post zdenek
Mon Feb 02, 2026 12:02 pm
Beautiful!
You did a lot of work!
I see you've stiffened the turntable; that's very good work.
Most importantly, the machine records with a new Swiss head.
If you manage to buy an original 14-inch Apollo master, I'd be happy to listen to your recordings and cuts! :)
Thelatheofus
Post: # 69014Unread post Thelatheofus
Mon Feb 02, 2026 5:19 pm
Really nice work !
May I ask how your lever to drop or lift the cutterhead works ?
spinnertownblanks
Post: # 69017Unread post spinnertownblanks
Tue Feb 03, 2026 12:40 am
This is great! Not sure it’s a ‘very basic record lathe’ anymore :) Amazing work and it will cut lovely with a Caruso
www.spinnertownblanks.com
ilovedrums247
Post: # 69018Unread post ilovedrums247
Tue Feb 03, 2026 4:43 am
Well it’s basic compared to what i take inspiration from, Neumann VMS series, Sillitoe, Flokason, etc… like a Honda Civic to a fleet of Rolls Royce autos :)
And no plans to cut lacquers, just pvc…maybe one day we’ll get there…
Here’s some pictures inside the suspension box, built with mostly off-the-shelf parts. The head drop uses a ball chain leftover from some home renovation
Fela Borbone
Post: # 69020Unread post Fela Borbone
Tue Feb 03, 2026 5:51 am
Amazing suspension box! Well done
zdenda.jircik
Post: # 69022Unread post zdenda.jircik
Tue Feb 03, 2026 7:44 am
Hi ilovedrums247,
I like your approach.. Machine looks really solid. I'm also curious how caruso head sounds..
Your suspension system look inspiring. I think that Neumann is difficult to copy, but you did nice simplified version. And there is a lot of opportunities for experimenting and fine tuning. If you don't mind, I will copy your design little bit. :)
Thank you for your sharing here.
Hope I can do it before I retire. :lol: Cheers from CZ
Thelatheofus
Post: # 69031Unread post Thelatheofus
Wed Feb 04, 2026 6:54 am
Thanks for the close up on the suspension box ! You make me want to try this kind of "real neumann lathe" type of carriage and suspension.
I asked because I chip diamonds too fast, and I'm wondering what people use in their suspension mecanisms. Lately I was putting the blame on my head drop/lift mecanism, but I see plenty of people not complaining about styli chipping althought they use mecanisms that are not as secure as the ones in a neumann or t560.
