Caruso swarf clearance
Dub Studio
Post: # 67096Unread post Dub Studio
Thu Mar 20, 2025 8:04 am
I am trying to work out how to remove swarf from under a Caruso head. It looks pretty tight down there!
I can see a 5mm curved recess... does the tube go there? What sort of tube is normally used? Does anyone have the dims?
Finbarr Saunders would have a field day with this post!
flozki
Re: Caruso swarf clearance
Post: # 67110Unread post flozki
Sat Mar 22, 2025 1:14 pm
There should be plenty of room since you have the 7-degree back angle.
Maybe on VRs, you don't use that piece, but you're free to set the angle as needed.
The curved milling was only implemented in the first series and is essentially useless, so it must be an early version.
Removing chips from the side is completely outdated, and I can't recommend it.
Instead, use 6mm x 0.2mm inox tubes (cheap drink straws replacement 6 for 5 bucks), flattened in the first 50-60mm.
That should work perfectly fine.
happy cutting
f.
BacktoDub
Post: # 67115Unread post BacktoDub
Sun Mar 23, 2025 4:10 am
Cutting on a Vr,Caruso head angle 9/10 degree with pressed blanks and enough space to set the vacuum tube,otherwise hammer it I little bit in th last part
BacktoDub
Post: # 67117Unread post BacktoDub
Sun Mar 23, 2025 4:30 am
I was still making adjustments on this picture Angle it s not correct,just to show you the space left to set properly.
I did hammer a bit the Vacuum tube and fit perfectly.
BacktoDub
Post: # 67118Unread post BacktoDub
Sun Mar 23, 2025 4:36 am
The Vaccum tube dont need to be that close to the stylus
SueDenim
Post: # 67128Unread post SueDenim
Mon Mar 24, 2025 8:23 am
Sent you a PM mate but I don't think you've picked it up.
