Record Lathe Question:45 lathe?
This is a special section, perhaps temporary, to help our man Timmy1 with his efforts to assemble a working 8J10 Wilcox-Gay Recordette for experimental record cutting. The reasons for this will be explained shortly, but please do check in and help! He's a great guy with a worthy project.
timmy1
Post: # 22692Post timmy1
Mon Jan 21, 2013 12:20 pm
Hi I was wondering if they made record lathes just for 45 rpm records? I would like to experiment with making 45 records provided I can get the blanks Thanks.
Re: Record Lathe Question
Post: # 22700Post tragwag
Mon Jan 21, 2013 2:35 pm
I would have to say no.
early record lathes were made in an era where there was only 78 RPM recording.
thats why you find a lot of suitcase cutters that only go 78.
after that, pro and semi pro lathes often went 33 and 78.
and when 45 RPM was introduced, it was simply an addition to the existing speeds.
I know that the Presto lathes can be adapted to go 45 instead of 33, etc.
each company had their own adaptation, but I am not sure if any company had only a 45rpm lathe.
Your best bet would be (depending on how deep you want to get into this):
-buy a suitcase cutter and modify it's speed (very very lo fi results)
-buy a semi-pro cutter (presto/rek o cut/etc)
-buy a modern dub cutter model and attach it to a Technics 1200 turntable.
as always, check the WIKI: http://lathetrolls.pbworks.com/w/page/22959575/The%20Secret%20Society%20of%20Lathe%20Trolls
Steve E.
Site Admin
Post: # 22702Post Steve E.
Mon Jan 21, 2013 3:09 pm
I do think there was some sort of japanese consumer/toy system that cut only 45s. hmmm...
EDIT: Yes! it was called the Vanrock Recorder E-101:
https://www.lathetrolls.com/viewtopic.php?f=1&t=2018&
ttp://www.youtube.com/watch?v=uLtnbCmq480
A variation (perhaps a simple rebranding) was called the Atom.
Re: Record Lathe Question:45 lathe?
Post: # 22717Post tragwag
Tue Jan 22, 2013 2:11 pm
wow! there you go :)
timmy1
Post: # 22719Post timmy1
Tue Jan 22, 2013 2:19 pm
tragwag wrote:wow! there you go :)
Thanks does any one know where i can get one? Also what kind of blanks is used with them.
studiorp
Post: # 22764Post studiorp
Wed Jan 23, 2013 3:26 pm
I had seen two years ago in UK on Ebay a disc lathe portable in excellent condition only for 45 rpm. It was a MSS Recording lathe.
For blanks "nema problema" (no problem), because you can cut everything, from polycarbonate to pvc, or other.
For example I had done experiments to 45 rpm on a 12" without problem.
Cheers.
Raffaello.
timmy1
Post: # 22766Post timmy1
Wed Jan 23, 2013 7:47 pm
Thanks so is MSS the name of the lathe?
studiorp
Post: # 22777Post studiorp
Thu Jan 24, 2013 4:41 am
MSS Recording Company was a British factory that had produced portable lathes and too discs for BBC during the WWII.
You can see the video of a lathe on youtube, and on Google there are a lot of articles of these machines.
timmy1
Post: # 22780Post timmy1
Thu Jan 24, 2013 9:19 am
I did not find any information on MSS Recording Company on youtube or much on google.
timmy1
Post: # 22805Post timmy1
Fri Jan 25, 2013 1:01 am
I am debating which type of lathe to get. I have a chance to buy a wilcox gay record lathe that needs the head demagnetized but it still works or I can wait and look for a smaller one the vanrock recorder but that is hard to find. Has anyone used the vanrock recorder and how did they like it thanks.
timmy1
Post: # 22812Post timmy1
Fri Jan 25, 2013 10:50 am
On the wilcox gay lathe I am think about buying the person says I does not record or play because the head has to be magnetized. He told me you reverse the needle to record and reverse it back to play. here is a youtube video not sure how easy it would be to repair
http://www.youtube.com/watch?v=yu9139LDIc4
Angus McCarthy
Post: # 22841Post Angus McCarthy
Sat Jan 26, 2013 12:36 pm
Is it an ebay auction? If so can you give us a link?
timmy1
Post: # 22851Post timmy1
Sat Jan 26, 2013 7:30 pm
Angus McCarthy wrote:Is it an ebay auction? If so can you give us a link?
Here is a youtube video of it
Angus McCarthy
Post: # 22857Post Angus McCarthy
Sun Jan 27, 2013 8:43 am
Is that the actual machine you are going to buy, or just one like it?
Steve E.
Site Admin
Post: # 22861Post Steve E.
Sun Jan 27, 2013 9:47 am
Make sure it can cut at 45! A lot of the earlier Wilcox Gay machines were pre-1948 and only cut 78.
That little suitcase thingy looks pretty cute!
Do keep in mind that you will have to spend money to get it to work.
timmy1
Post: # 22986Post timmy1
Wed Jan 30, 2013 11:08 pm
I was just wondering if you could use a transcriber to record on to a cdr
Angus McCarthy
Post: # 22997Post Angus McCarthy
Thu Jan 31, 2013 1:09 pm
What do you mean by "transcriber"?
timmy1
Post: # 23028Post timmy1
Thu Jan 31, 2013 9:47 pm
Angus McCarthy wrote:What do you mean by "transcriber"?
They had a transcriber for recording notes which used a small disk at 16 speed years ago.
Angus McCarthy
Post: # 23044Post Angus McCarthy
Fri Feb 01, 2013 7:34 pm
Oh, you mean a Dictation Machine.
Well, assuming you can find a model with a spindle that would let you fit a CD, and as long as you have a good embossing stylus, it should be quite possible.
