Semar choice 😁🔥
Semar
Re: Semar choice 😁🔥
Post: # 68721Unread post Semar
Sat Jan 10, 2026 12:51 am
spinnertownblanks wrote:
Fri Jan 09, 2026 3:40 pm
If using Pro Q3 go with Natural Phase
Thanks 👍
Semar
Re: Semar choice 😁🔥
Post: # 68732Unread post Semar
Mon Jan 12, 2026 8:08 am
Hello cutters !
Yesterday, i ve re-mapped my head with natural phase
So third picture the eq i first made a few times in zero latency
In second, the on I made yesterday, polycarbonate, louder power to the head and a lighter stylus
It seems to be very similar, a little bit slided to the right
And in first picture very interesting for me, i ve tried (at this time) to make a second iteration but the results was very weird
i retry yesterday and the result looks at a little bit as a riaa curve
I ve now to try it with music and perhaps make a 3rd iteration but interesting...
Semar
Re: Semar choice 😁🔥
Post: # 68903Unread post Semar
Tue Jan 27, 2026 2:29 pm
A small donation made just now, because I am not rich but involved, not a donation TO GET A FAVOR, a donation for the community, if the troll thinks he has trolled, let him be satisfied in realizing that his name does not appear, that generosity and kindness have no label, ego is useless....
Semar
Re: Semar choice 😁🔥
Post: # 68905Unread post Semar
Tue Jan 27, 2026 2:31 pm
And to all my other friends, you know me, sorry for what I just said 😁✌️
Semar
Re: Semar choice 😁🔥
Post: # 68906Unread post Semar
Tue Jan 27, 2026 2:41 pm
Fela Borbone wrote:
Sun Jul 06, 2025 12:29 pm
Pm sent
Help without ask for nothing for example....
And again a very big thanks Fela Borbone for your help
And thanks lathe trolls for this helpfull space
Semar
Re: Semar choice 😁🔥
Post: # 68907Unread post Semar
Tue Jan 27, 2026 2:48 pm
Let's not finich on this , music first !
video_20251005_142623.mp4
farmersplow
Re: Semar choice 😁🔥
Post: # 68910Unread post farmersplow
Tue Jan 27, 2026 3:12 pm
That sounds pretty good. Of course, it doesn't come across as clearly through the phone's microphone. Even so, you can already hear a good dynamic range. Perhaps you could record an album and upload the recording here?
Anyway, you're making good progress. Keep going, keep going, keep going, keep going... :D :D
Semar
Re: Semar choice 😁🔥
Post: # 68922Unread post Semar
Wed Jan 28, 2026 12:15 am
Thanks, OK i will upload a record
The sound need some highs and bright but not to bad
I m also thinking to make a saphire stylus to improve the things
farmersplow
Re: Semar choice 😁🔥
Post: # 68923Unread post farmersplow
Wed Jan 28, 2026 2:44 am
Sapphire sounds good (embedding). You want to improve, that sounds excellent. But don't forget the 20:80 rule!
A 20% improvement costs 80% more time and money.
All the best for the future.
Semar
Re: Semar choice 😁🔥
Post: # 68927Unread post Semar
Wed Jan 28, 2026 5:00 am
🤣🤣🤣🤣80 /20 is the deal 🫡
Semar
Re: Semar choice 😁🔥
Post: # 68928Unread post Semar
Wed Jan 28, 2026 5:03 am
I have some pre-cut sapphires that I got at a very good price, and I'm going to try mounting them on aluminum stems. Then I'll need to refine and polish the cone. Has anyone ever tried this kind of thing?
Semar
Re: Semar choice 😁🔥
Post: # 68934Unread post Semar
Wed Jan 28, 2026 2:06 pm
So, I'm thinking of doing a hybrid collage/bezel method, but in reverse. I'll share all my experiments and methods here—it's a brilliant open source.
Semar
Re: Semar choice 😁🔥
Post: # 68936Unread post Semar
Wed Jan 28, 2026 2:11 pm
The idea is to drill a hole in the end of the aluminum rod to the diameter of the sapphire (0.8mm), then glue it in place, point upwards of course, and finally fold the edges of the aluminum over the sapphire and possibly add more glue to ensure strength...
Semar
Re: Semar choice 😁🔥
Post: # 68937Unread post Semar
Wed Jan 28, 2026 2:13 pm
Finally, the machining and polishing of the sapphire cone will begin, followed by cutting the stylus to the correct length. After that, everything will be fine 🤣🤣🤣🤣
Semar
Re: Semar choice 😁🔥
Post: # 68938Unread post Semar
Wed Jan 28, 2026 2:15 pm
So, plan C is done, it's as good as done, 80/20 ( 🫠Thomas), and we're moving forward. Health and happiness to you all, friends😁
farmersplow
Re: Semar choice 😁🔥
Post: # 68939Unread post farmersplow
Wed Jan 28, 2026 3:12 pm
A brief overview of what I've been doing:
1. I manufactured a 0.7 x 0.7 mm die using wire EDM.
2. I pre-drilled the diamond tip's recess (1:20 taper).
3. I created a square hole using the die.
20250408_155748 -8.mp4
(80:20) :lol:
Semar
Re: Semar choice 😁🔥
Post: # 68940Unread post Semar
Wed Jan 28, 2026 5:25 pm
(80:20) :lol:
I'm glued to your answer, and my eyes have no words to send to my brain.😶😶😶😶
Semar
Re: Semar choice 😁🔥
Post: # 68961Unread post Semar
Fri Jan 30, 2026 1:08 pm
Wish me luck! Tomorrow I'll attempt the assembly: an aluminum-iron alloy rod, a sapphire crystal, then a silent cut test. If it works for tracking, I'll redo the mapping.
Semar
Re: Semar choice 😁🔥
Post: # 68962Unread post Semar
Fri Jan 30, 2026 1:17 pm
P.S.: I said open source, so the aluminum-iron alloy rod is a bicycle wheel spoke; it's very light and very hard. I don't know if it will work, but I'm sharing my experiences.
